650 header clamp broken
katscott
Has thanked: 3 times
Been thanked: 7 times
Post by katscott » Tue Jan 11, 2022 10:38 pm
I have an original 4 into 2 for the 650 kat. I also have a dilemma one of the header clamps is broken. So does anyone have one please and second how the hell did Suzuki fit them?
Re: 650 header clamp broken
Post by fossie » Wed Jan 12, 2022 12:14 am
They were fitted before the pipes were welded to the silencer / collector. :roll:
An alternative could be the centre pipe collects from an 1100/750 SZ/SD .they are in 2 halves , I think they may still be available.
I have some motad ones that you could have but you'd need to cut them in half to get hem on then alloy weld back together. :P
GSF34058
Has thanked: 32 times
Been thanked: 60 times
Post by GSF34058 » Wed Jan 12, 2022 8:52 pm
............ but you'd need to cut them in half to get them on then alloy weld back together. :P
How about cutting the flared end off the top of the pipe, putting the clamp on, then welding the flared pipe end back on. Easier than welding alloy, and the welding scar should be hidden by the clamp. Does that sound feasible?
David
Post by fossie » Wed Jan 12, 2022 9:04 pm
It would be easier probably, but you may have to make a complete new top of the pipe because the metal will be compromised .
katscott
Post by katscott » Thu Jan 13, 2022 9:53 pm
Thanks for advice. I also have motad type but would look odd. I also thought about top end of pipe. My idea was grinding the outer sleeve off and fitting new header clamp and fitting a new sleeve to replace.
