Throttle bogging out
blackdog
Post by blackdog » Fri May 06, 2011 11:24 am
Hi guys/gals
After some imput
My Kat 400 has just had a rebuild
I used the carbs from my other Kat (which I know worked)
So I've set them up with the carb tune
bottom fuel screw ' 2-3/4 turns out
reving nicely and returning as should
but when tacking it to the MOT tester's
she reves ok but a big flat spot in the middle reve range
The only thing that different between my two Kat's
is the I've got probs with has a straight through can fitted???????
Is there any adjustments to make
of tests I can do??????
Any advice gladly needed!
Si
Re: Throttle bogging out
Post by fossie » Fri May 06, 2011 7:42 pm
400 very prone to carb set up.
The manual set up says 1'75 turns out for pilot screw. needle clip 3rd groove. However the straight through zorst may need a notch move on the needle clip.
superfly
Post by superfly » Fri May 06, 2011 10:05 pm
Hi Fossie,
Do you have a transalation of the manual ? I have only a japanese version...
So could do with more english word :-)
Post by fossie » Sat May 07, 2011 9:38 am
There is no english version but tech stuff is already in english.
Post by johnr » Sun May 08, 2011 4:22 pm
have you got the air filter insert?
blackdog
Post by blackdog » Mon May 09, 2011 1:10 pm
that's one difference between the 2 Kats
the 1 thats bogging down has a new orignial air filter with fitted insert and straight through exhaust
and the other standard exhaust and no air filter insert fitted but that runs fine
Been thanked: 201 times
Post by Pedda » Mon May 09, 2011 6:10 pm
So you gave the answer, I believe.
