650 cam chain adjustment??
Doc44
Been thanked: 2 times
Post by Doc44 » Sat May 09, 2015 7:18 pm
It seems that the cam chain is getting a little noisy on my 650 but as far as I can tell the adjustment is automatic, does anyone have any suggestions as to what to do? Maybe a stuck adjuster? Is this a common issue?
Cheers.
Re: 650 cam chain adjustment??
Post by fossie » Wed May 13, 2015 1:14 pm
A laid up 650 will stick the adjuster.
On cam chain adjuster is a wheel! In centre a 10mm nut that is lock nut for the adjuster blade.
Slacken it off twirl the wheel ....it will only go 3/4 turn , let it spring back and tighten the nut.
Obviously with engine off.
Doc44
Post by Doc44 » Wed May 20, 2015 7:24 pm
Thanks fossie. Just got around to doing it tonight, spot on again!
