Gasket set
Gasket set
Is it worth buying suzuki gaskets or are the pattern ones Iv,e seen on ebay ok (kat !000 ).As I need rocker cover and exhaust gaskets
Re: Gasket set
if you only need a rocker gasket get the Suzuki one, it will seem quite expensive for 1 gasket but some aftermarket ones are mmmmmmmmmmmmm-OK.
As for exhaust gaskets the are generic to pipe size and you buy them on e bay quite cheap.
Re: Gasket set
Thanks paid suzuki my weekly wage for there gasket and saved loads on the generic exhaust gaskets
