Did you get valve tool sorted or do you need one?
Chasing the smoke
Re: Chasing the smoke
I'm back from visiting my 650 in 45 degree France
- Has thanked: 644 times
- Been thanked: 247 times
Welcome back to Cool Britannia, hope is was a good holidayfossie wrote:I'm back from visiting my 650 in 45 degree France![]()
I sent Blix my one for now (cheaper version (or maybe not as I think it was genuine Suzuki) with the clear yellow plastic handle.
I hope you are going to do a video startup. How about Facebook Live (have no idea what it is but sounds good!). We could all grab a beer and then watch as you do your maiden startup sans the smoke hopefully.
- Has thanked: 122 times
Good stuff Mick.
Your Ventura rails are in the post!
Post the video on here, I don’t do Face-O-gram
Wish I could join you in Fintry with a pint of 80 shillings...
Blix wrote:Timing checked, it was a bit out tbh, this one is especially for UB
Mick was just showing me after this thread some time back...!
viewtopic.php?f=40&t=7843
He hastened to add to didn't pay the price of the Ebay advert! I'm still tempted - and now I see how good they look...
We could do a group purchase, but then I realised that most want a whole bike for that much
switch is simple enough, take the wire off and touch it to earth and the light should come on, its just a brass plunger held down by a spring. you didnt paint the casing did you? if so, did you check that the inside of the switch is bare metal, cos the switch plunger needs to be able to earth out.
When I started mine for the first time I did the "Spin it up with no plugs in" to check for oil pressure.
Good job really as the person I got the engine off had been in, looking for bits to swap to an 1100.
I knew he had been at the clutch so I had sorted that one, but missed the poorly re-fitted circlip to the oil pump drive......
But that's why you do these dry starts on engines.
Do you have the Oil Pressure light on and not going off? Which would imply no oil pressure. Or is light off at all times? Which would suggest a lamp/switch fault.
Another quick and dirty check is to remove the end plug from the oil gallery, and spin up the engine. If the pump is working it will cover your right leg in oil.
