ABS retrofit
- Been thanked: 62 times
Re: ABS retrofit
Do you mean the new or original 1000??
Can't see the point of trying to make it work on an 80's relic, be better off trying to simply improve the std fit set-up
As for the new one then no doubt far less costly to buy it with it already installed if indeed its an option??
Re: ABS retrofit
ABS ....on a bike is the work of the F**********devil ..uneven road surfaces at braking areas confuse the system and the lever goes hard .
Paragraph from both * onda & Suzuki owners " remember you have ABS fitted so may need a longer braking distance
As Blix said you could lock the rear but you will remember the feeling just before it does ...that's abs but just in the human head mounted black box ..
Jonty
- Has thanked: 47 times
- Been thanked: 19 times
Re: ABS retrofit
Thanks all for input.
I hear so much criticism of Kata braking and tyres and so much talk about ABS on bikes, I wanted to look into it.
Re: ABS retrofit
There are 3 offs on circuit all with Suzuki V storm ( mines nearly 100.000 another 80, 000 another 50.000 miles , with ABS , the brakes are fine except for bad road surfaced areas ...quite a lot around Manchester , and we all dislike it ...even the newest chap , who actually didn't believe us , but at least we ain't got that bloody out to kill you linked brakes fitted to * onda's .
( in winter mainly , but also filtering )
There isn't actually anything wrong with Kat brakes to be honest when ridden like an 80's bike , the days when rider input was as important performance ....I believe the comments about the brakes are from people who have a more modern machine aswell or borrowed a Kat and have become reliant on the other vehicles ability to do the thinking for the rider , but if that's your thing why have you bought an 80's bike ....
Better design certainly , but if it's to pose buy the Tamiya model .
Jonty
Re: ABS retrofit
Katana is last bike I rode, so it's all I know, haven't ridden anything newer or since. I find back tyre squirms a bit on motorway lane changes, I worry I use too much front brake, but love the ride, handling, suspension everything, I guess its hearing previous owner go on and on about it handling like a dinosaur, braking and tyres are terrible, you need to ride a new bike etc etc.fossie wrote: ↑Wed Aug 17, 2022 7:39 amThere are 3 offs on circuit all with Suzuki V storm ( mines nearly 100.000 another 80, 000 another 50.000 miles , with ABS , the brakes are fine except for bad road surfaced areas ...quite a lot around Manchester , and we all dislike it ...even the newest chap , who actually didn't believe us , but at least we ain't got that bloody out to kill you linked brakes fitted to * onda's .
Better design certainly , but if it's to pose buy the Tamiya model .![]()
I'd been considering wider back tyre and replacing shocks, but to be honest it really all feels ok as is, I like it.
Maybe I'll test ride a new bike with ABS and see what I think some time.
Jonty
Re: ABS retrofit
original.stockcar wrote: ↑Tue Aug 16, 2022 7:30 pmDo you mean the new or original 1000??
Re: ABS retrofit
If you want to try some crap brakes, try out an X7. Even a completely refurbished braking system is absolute rubbish. Just give yourself a bit more time and space. If you want to go fast, get a modern bike. I'm not being rude, it's just how old bikes are. You seem to be really happy with your big Kat, so just enjoy it for what it is.
I think a wider rear tyre may make the squirming worse.
I've never ridden an ABS equipped bike, so in my mind I don't need it. However, I do ride very slowly these days!
