Back in. Which are the correct plugs as I have online information saying both are correct? Thanks.
Spark plugs
Spark plugs
Hi, need to change plugs on my 82 gsx750 katana sz, took out NGK D7ea,s and have NGK D 8ea,s to go
Currently gsx750 katana sz,s1 82 aka moggie
2011 Harley dyna streetbob aka hoggie
In 86 gs650m katana
In 02 gsx400 katana grey import
And many bikes in between.
In 86 gs650m katana
- Has thanked: 122 times
- Been thanked: 257 times
Re: Spark plugs
Had a look at my Suzuki manual.
Either NGK D8EA for E-01, 24, 25, 30, 34
Or DR8ES for the others!
So if you have a Germany, Ireland, Croatia, Dunno, Bulgaria market bike then the book says D8EA.
But to be honest it probably wont make enough difference to worry about.
I would bung in the ‘8 as it’s the stated heat range.
Re: Spark plugs
I don't know why it's got 7's in ...has it been rejetted....for somewhere other than our climate?
Re: Spark plugs
After I posted that, I looked at the NGK place.
They suggest ‘7 heat range. Just to confoose uz
But I’d still throw some ‘8s at it. Just like Skruffy Kat is running.
Re: Spark plugs
The NGK catalogue on line isn't usually UK , It's Yank ( spelling Timothy) .
Used to get issues when I worked in parts dept with people looking on line then ordering ....then complain about poor running , like it was our fault.
Personally I have always used DR8 ES L as it is a superceed to EA and easier to come by.
Re: Spark plugs
Thanks, I will put the “8,s in “. Bikes running standard air box etc so not known why it had D7ea in.
Ps was Italian import.
In 86 gs650m katana
In 86 gs650m katana
- sparki
- Committee Member
- Has thanked: 80 times
- Been thanked: 72 times
Re: Spark plugs
so engine number starts with R701 then? if it does its a nicer 750 than a GS75, better cams in it
Re: Spark plugs
Hi, yes the engine number is R701, and it’s running well with the d8eas in.
In 86 gs650m katana
In 86 gs650m katana
