Airfilter adapter
Airfilter adapter
Post by fossie » Sun Feb 12, 2023 8:41 pm
The airfilter for the 400/ 250 Kat is 13780-45D00. Which is available but can be a while to arrive .
The alternative is to buy a GS 500 ( twin) airfilter 13780 01D51 and use one of our trumpets that simply fits in the top and you can adjust to suit .
This item obviously can be reused in next filter saving in the long run .
£15 incl postage buys the trumpet .
Has thanked: 644 times
Been thanked: 247 times
Re: Airfilter adapter
Post by Uncle Bob » Mon Feb 13, 2023 10:39 pm
As in other post (New Users), I'm waiting for one to be sent...
Post by fossie » Mon Feb 13, 2023 11:41 pm
I have a few left , send PM with postal address and it shall be on its way?
Post by Smallkat » Wed Feb 15, 2023 10:59 am
What exactly is the purpose of the trumpet? It can't be to tune the intake length?
Post by fossie » Wed Feb 15, 2023 8:02 pm
It is to increase the volume pressure intake .
If you slip the trumpet in the filter all the way out and start the engine it sucks it down adding pressure through the filter to the carbs.
When I first got my 400 filters weren't available and we hadn't made the aftermarket adapters , I just found a connection from an old VAX Hoover was the correct diameter and cut it to length...adjusted it a few times, it was still there when I rehomed it 120,000 later .
There was a flat spot without it , gone with it ....until the carbs wore out, literally ..
Post by Smallkat » Thu Feb 16, 2023 11:26 am
I better have one then. Same paypal address as for membership?
Andy Ramsay
Post by Andy Ramsay » Thu Feb 16, 2023 12:47 pm
received this morning Fossie, ta muchly man...
Post by fossie » Thu Feb 16, 2023 9:53 pm
Oooh nearly missed this post ....yep same PayPal address , PM me with postal address please ...I know I've had it once but we cannot assume it'll be the same ...
So now only 1 left . :o
Post by Smallkat » Fri Feb 17, 2023 10:52 am
Money sent. Doing PM next.
