Popup Speedo Failure
payton6uk
Has thanked: 1 time
Post by payton6uk » Sat Nov 19, 2016 5:19 pm
Just come back from a pleasant night time run...... and my speedo failed!
A quick check under torch light, nothing obvious.. I'll have a look in the morning, is this a common thing, any advice on what to check first?
Thanks in advance...
Has thanked: 122 times
Re: Popup Speedo Failure
Post by Kryten » Sat Nov 19, 2016 10:48 pm
First thing I would look at is the drive cable, my SZ failed the night before it's last MOT. Cable had dropped off the back of the speedo gearbox.
Did you notice if the odometer was still clocking up the Kilometres? If it was then it will be a faulty mechanism driving the needle.
payton6uk
Has thanked: 1 time
Post by payton6uk » Sun Nov 20, 2016 3:02 pm
Snapped cable ...Phew!, thanks Kryten for your advice. :D
